Extra 10MHz on the core isn't going to make any odds and the KFA2 has slower shader clocks by quite a margin - which will make a bigger difference in modern games.
Few weeks im going to decide whats my permanent card. I have a 470gtx but it gets up to 102c in my case ( 82 full load without case side on and in a cool room) So thats not going to be a permanent solution. I was thinking just 2 460gtxs for a few years.
Running a 5770 for now which i have no problems with. But its slow![]()
OCUK have got the spec wrong on the shader for this. It should read 1620Mhz.
Makes sense - still extra 20MHz shader/10MHz core isn't going to make the difference of 1fps even unless your pumping out 200+fps.
Its £10 more expensive than the cheapest HD5850's and £70 more than the cheapest HD5830.
Oh dear, the Galaxy is off my wish-list if this is right:
Taken from the HardOCP review...
"This is a somewhat subjective portion of our hardware testing, simply because the equipment required to objectively record sound pressure levels approaches ridiculous. That said, without manually turning the GPU fan speed on either the 1GB or the 768MB GeForce GTX 460, we simply could not hear these things. Even at full load with the fan spindle wound up, it was silent compared to the other fans in the system. Also conspicuously lacking was the whine produced by vibrating chokes commonly heard from some NVIDIA cards.
In short, the reference design GTX 460 video cards we tested were dead silent. The Galaxy GeForce GTX 460 1GB video card, on the other hand, was not. From the moment we plugged it in, the fan was whiny and loud. And when we fired up FurMark, or any 3D game, it only got worse. Not only was it audible over the other system fans, it was audible over the speakers, and even the office pedestal fan. So while Galaxy has perfected cooling, they have a ways to go to reducing the noise level compared to the reference fan"
I know, makes for a hard choice. However, now that the Galaxy and Gainward versions are off my list (due to the noise factor), it's back to the lesser OC'd Gigabyte, which is £13 cheaper than the cheapest 5850.
£13 well spent ?
Does this also apply to the Sonic Thunders? If so, they will be going back to OcUK.![]()
