No megaflow for the side or does it come with one already ?![]()
It has a MegaFlow (plain black, no led) installed already, I have thought about replacing it with a red MegaFlow though.
Does the preinstalled Megaflow on the top that comes with the case have a LED?
So are people just adding a single LED fan or purachsing two and replacing the factory default?
I can only find LED 200mm Megaflows for sale.
Coolermasters online shop in the netherlands will sell you 200mm non led fans that are the same spec as the megaflows.
I have just purchased 2 blue led coolermaster mega airflow fans of that big auction site
Cheers
mrix
Does anyone think it may be worth replacing the 3 x 200mm fans with the HAF-X with these for more quietness and better performance :-
http://www.xigmatek.com/product.php?productid=87&type=specification
and the 140mm with one of these :-
http://www.noiseblocker.de/en/produkt_luefter_nb-blacksilentfan-xk2.php
the cost would be £65
i guess the pictures makes it look like theres a lot of cables inside the case but tbh theres only about 6 cables that i couldn't be routed behind the tray because the side door wouldn't close, lol. i guess thats the downfall of having a lot of hardware.gareth170,
Nice rig, lots of cables, I have recently bought a few of the NZXT pre-braided cables to clean up and cut down on the amount of cables needed. I had a lot of molex-fan adapters, which took up a lot of space.
Do you find a difference in temperature between having the CPU cooler vertical and horizontal?
