*** The Official HTC Desire (Bravo) Thread! ***
Look at your desk, look at the screen now back at the desk NOW BACK AT THE SCREEN! It's now a wallpaper!
No UK Desire have SLCD yet. I wouldn't mind either, the Sony screens are said to be as good as an AMOLED and are exclusive to HTC only so good to know.
OK, I've been fiddling and testing the 720p recording for a little while now and come to the startling conclusion that it's not complete rubbish afterall.
I've fiddled and fannied around with my media_profiles.xml and I get a much better framerate/recording quality, the alterations I've made seem to match up with ones tested in the djdroid thread on XDA developers, I've uploaded it to http://mfi.re/?15mc7ygv0dxmmnj if anyone wants to give it a go (save it in your android-sdk-windows/tools/ folder), instructions on how to push it below:
1. Get into recovery
2. Open a command prompt (as admin, not sure if it makes a difference), in your android-sdk-windows/tools/ folder
3. Type adb shell
4. Type mount /system
5. Type exit
6. Type adb push media_profiles.xml /system/etc
7. To check if it's definately uploaded you can adb pull the file back down and open it.
8. Type adb reboot
9. Profit?
Is that only for 720p or would it apply to 480p as well? I don't use SenseUI ROMs as they are inferior for bluetooth pairing support so currently rely on h264 480p !
You can tinker with it if you're having bother with 480p recording.
Unfortunately what it doesn't do is fix the awful light sensor which seems to take an age to recalibrate.
DeFrost 2.1 is out now and the ambient light sensor is completely fixed, brightness etc scales perfectly and battery should be improved vastly too!
i seem to have done something to my phone flashing it to AdamG's Official froyo Sense rom, its bricked my sd cards and now ive got not signal.....
3. Type adb shell
5. Type exit
8. Type adb reboot
9. Profit?
link broke?
I've got a bit of a problem with my new desire. I keep getting messages saying i have missed calls, but i've been sat next to my phone and it hasn't even rang?
I'm on orange.
ive noticed this! its very irritating. Hopefully its something that will be resolved at some point.
Im also on Orange
