19 Jul 2010 at 18:00 #1 Scania Scania Caporegime Joined 25 Nov 2004 Posts 26,042 Location On the road.... Is it particularly difficult? Mine seems to have packed up (half the display is dark but still readable) my Google skills seems to have failed me, anybody got any previous on this? Ta.
19 Jul 2010 at 18:01 #2 robnut robnut Associate Joined 12 Jul 2005 Posts 1,453 Location Dursley remove tray undernearth, push tabs up under the obc, obc slides out, bulbs in top iirc.
19 Jul 2010 at 18:02 #3 paradigm paradigm Caporegime Joined 26 Aug 2003 Posts 37,508 Location Leafy Cheshire Not difficult at all. Feel in the cubby hole under the OBC for a hole that allows you to get a finger behind the OBC and push it out. Bulbs are then twist out, 3 of them on the top of the unit.
19 Jul 2010 at 18:52 #4 Scania Scania Caporegime OP Joined 25 Nov 2004 Posts 26,042 Location On the road.... Cheers guys - I did not want to start pulling it to bits & inevitably break something.... Halfrauds for a replacement I'm guessing?
19 Jul 2010 at 19:01 #5 NickXX NickXX Soldato Joined 19 May 2005 Posts 7,049 I had to get my bulbs from BMW (strange fitment), they cost peanuts though.
19 Jul 2010 at 19:05 #6 Scania Scania Caporegime OP Joined 25 Nov 2004 Posts 26,042 Location On the road.... NickXX said: I had to get my bulbs from BMW (strange fitment), they cost peanuts though. Click to expand... Nice one Nick That saves me a wasted trip tomorrow and gives me an excuse to go test drive something if I can blag it!
19 Jul 2010 at 19:17 #7 NickXX NickXX Soldato Joined 19 May 2005 Posts 7,049 R420LA6X2/4MNA said: Nice one Nick That saves me a wasted trip tomorrow and gives me an excuse to go test drive something if I can blag it! Click to expand... Heh yeah - certainly with mine (manual controls), it was dealer only as the bulbs come in their own holder. Either way, should be cheap from a dealer.
20 Jul 2010 at 13:42 #8 Scania Scania Caporegime OP Joined 25 Nov 2004 Posts 26,042 Location On the road.... Ahh! true to form, sourced some bulbs, pulled the thing out and now on its re-assembly, it won't work at all.
