LOTRO to go 'free to play' in the autumn....
Only image i have taking so far
How do i go about using the points? or is it all ingame?
i cant see anything in the CoG account settings etc
Its not gone live yet so you won't see anything. From what I'm seeing in regards to beta shots, you will spend the points in game. As a lifetime VIP you need to log in once a month to be eligible to collect your points.
Ahh cool , as long as they refund the points that we are missing each month ill be happy then :P
We're not missing anything at present. The game doesn't go F2P until September iirc and I daresay all beta points will be reset (probably be given an item for their troubles). To be perfectly honest I'll only be using my points to pay for expansions.
Any info on what the points can be used for?
I'll be primarily using mine to pay for the expansion packs, however I understand you will be able to buy both gear and perks usually offered via Destiny Points via the new item shop.
ahh i have all 3x expansion packs anyway ill save em for a rainy day :) or new expansions if any.
