OCUK EXTREME H2O GEFORCE GTX 480 1536MB GDDR5 PCI EXPRESS GRAPHICS CARD
11 Dec 2005
Cheshire
OcUK Extreme H2O GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card @ £495.99 inc VAT
The OcUK Extreme H2O GeForce GTX 480 combines the fastest single GPU card on the planet with the most effective cooling solution. No need to have your Fermi card at 90c anymore, the EK GTX 480 Full Cover block comes pre-fitted and provides superb cooling with stylish looks. The OcUK Extreme H2O GeForce GTX 480 is available with a choice of block options, either choose nickel acetal or nickel plexi to match seamlessly with your system. With the option of the ultra stylish backplate, your Fermi will be the slickest on the block. All OcUK Extreme H2O GeForce GTX 480's come standard with the EK single slot 480 bracket, so you can store extra PCI devices in the slot below your card for enhanced expansion. With features such as cinematic DirectX 11 graphics, CUDA and Nvidia PhysX technologies.You can expand your visual real estate across three HD displays in jawdropping stereoscopic 3D and experience immense framerates with blistering graphics.
- Voltage Tweak Technology
- Core Clock: 700MHz
- Memory: 1536MB GDDR5
- Memory Clock: 3696MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 480
- Shader Clock: 1401MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 1 Year
Only £495.99 inc VAT.
ORDER NOW
Hi there
I've just been looking at the card the OcUK tech team has been putting through it paces the last week and well lets just say its very flash bit of kit. :)
At least the price isn't ridiculous like the EVGA at £600.
Good on OcUK for providing for those who don't like voiding their warranty by watercooling...
I thought something like a graphics card is covered by a warranty longer than a year even if the dealer you buy it from only provides one year?
Still an interesting looking product though :)
The single slot bracket is a really nice touch and bear in mind this is not an asus product (i'm guessing here but thats my understanding), ocuk put the cooler on themselves (can be a good or bad thing depending on if you like mounting your own blocks). If you fit the block yourself and something goes wrong your in the hands of the asus rma process if you refit the air cooler, at least with this the block is fitted and you still have warranty. Only alternative is the evga hydro at £100 more it does offer a lifetime warranty though.
1 year warranty = total fail.
More warranty than blocking a card yourself
To be fair, it is one years warranty more than both my watercooled 480's...
Good point
It would have needed to be £100 cheaper to tempt me. Very nice product though.
So you want a premium watercooled GTX480 for cheaper than a value aircooled 480? Good luck.
I would also like to remind everyone. The Watercooled card has 1 year warranty with us however the card by itself has a 3 year warranty as we are able to re-fit the cooler for the Asus RMA process.
There are cards available that you can remove the cooler from without voiding the warranty that is longer than 1 year.
OcUK even sell the Zotac cards!
Nice U-turn. :D
