I'd wager that theres about 0 chance a GE+T will take 700hp. There's a reason why they are worthless.
And you base this on what exactly?
There are a fair few NA-T 2JZs making big numbers in the states. Look it up.
How many run 700hp reliably?
A GTE will, that's proven, even if given extreme punishment. Just look at the DW S15, been running close to 700hp for 4 years and never had an engine blow despite being given absolute punishment.
I think your gonna find it harder to buy and build a car that does 700bhp all day long, 365 days a year
The DW S15s 2JZGTE is far from standard internally.
Ive heard of a 1.5 Vtec engine that'd been taken over 700bhp believe it or not.
I just think in terms of ease a massive engine most likely a large lump of american iron is going to do it most easily
You dont need 700bhp driving down most roads, without 4wd the torque is probably going to be a liability when you arent paying attention
Ive always liked the idea of variable boost or something where you have the power only when required for the weekends, etc.
I think on superchargers you can sometimes just change the ratio with a tighter rubber belt or something easy like that and it'd make more power.
Lower or no boost improves mpg and reliability thereby giving you best of both worlds or is it not that simple![]()
No, i'm pretty certain it's all stock.
As I said then, it's a stock bottom end just with ARP bolts. Some initial teething troubles but nothing since then. The GE and GTE crank are identical, that's common knowledge.
I had a Ford KA![]()
Trivial items. The crank, rods, and crucially the pistons are stock. This is of course what I was getting at all along.
Was it black and the latter half of your name beginning with W?
Because it has weaker, higher compression pistons. Jesus christ :/
Not sure on prices of below components as I'm taking a "spec list" from a MkII Golf of somebody I know that runs at santa pod
Mk2 Golf
Audi 1.8 20v Turbo (AGU code)
82.5mm J.E Pistons (making it 1.9 )
Scat 20mm Connecting Rods
Siemens 870cc Injectors with Fuelab Adjustable FPR
Garrett GT35R Turbo
Ross Machine Racing Inlet Manifold
ADR N/A Inlet Camshaft
Interglactic Tubular Turbo Manifold
Tial 44mm External Wastegate and Tial 50mm BOV
PWR Chargecooler
Earls Braided Hose and AN Fixings
2 x Bosch 044 Fuel Pump
Schadek Oil Pump
APR headbolts
Supertech Inconnel Valves and springs
IIRC after that lot its running 600bhp then an additional 25-150bhp on nitrous
It is probably out of the budget but hey ho
With Uprated Main Bearings. And Uprated Big ends. That is not "All stock".
Mk2 Golf
Garrett GT35R Turbo
PWR Chargecooler
Schadek Oil Pump
APR headbolts
