Bit of an update, things have pretty much ground to a halt as I've had an expensive few weeks, but pretty much all the little bits and pieces needed have been bought now, basically just the camshaft to buy now. In the mean time I thought I'd spruce up the cam-cover a bit. I was going to go for a polished 'mirror' finish, but gave up because:
A - It was too much like hard work and couldn't be arsed any more
B - It's been done to death.
So I decided to stick with the black/silver theme of the car and paint the cam cover accordingly:
Satin black with silver 'accents'. Finish could be better, but I'm pretty happy with the result. I still need to flat and polish the raised rectangular silver part, I've left it as bare alu and will try to get a nice shiny finish on it.
Yep, it's the norm when using R1 carbs. It's provides more than enough flow, but the main reason for using it is you don't have to mess about with a pressure regulator, the R1 pump is 'self regulating' when used with the R1 carbs and always delivers the correct amount of fuel.
It is huge fun, puts a smile on my face every time I drive it. If you do want one I wouldn't wait too long if I were you, prices seem to be climbing very quickly, you are looking at £1.5k+ for good ones now.
