New build should be faster?
18 Feb 2010
Liverpool
So I just got a few new games to test out the rig I just finished (in sig)
Pop in CoD4 and at 1920x1080 with no AA i was getting about 10 fps, this can't be right can it?
5770 benchmark
According to that I should be getting above 60fps.
Don't think it would be anything other than the GPU causing problems, quad core and 4gb RAM should be fine for most games, no?
Will test Fallout 3 and Bioshock later.
Drivers are updated for the card, on 10.5 as I heard people where having issues with 10.6?
Not updated the game, would this need doing? Where exactly would I go to do this?
Thanks for any help.
Heaven benchmark results:
5770 benchmarks can be found here the score is higher, but my res was higher, should i try at 1680x1050?
does look low.
catalyst driver settings set to application controlled?
you may can now try cpu-z and post up some images of what it says, cpu info, ram info, motherboard info. I know your sig says what you got, but this will show more detailed info, such as frequencies and stuff
Had a look on the control center, could find that option, could you be a little more specific, might just be me being blind.
think its under advanced settings, not used ati for along time, sorry.
it will be there, you get a few basic settings, but one tab along the top gives you every 3d setting on one page.
the graphics card forum may be a better place?
edited my above post too.
Ok I think I found it, thanks.
Will get some CPU-z stuff up in a sec.
it says single channel? you got the memory sticks in the right slots?
thats all i can see wrong, it looks the same as my 955cpu, ignore the 800mhz cpu speed, thats just cool and quiet enabled, you can disable this, just checked cpu-z on mine and compared every screen against mine.
must be a driver issue or setting.
I think so, according to the mobo instructions I have them in B1 and B2.
You can see what slot they are in in this picture:
pull the one closest to the cooler out, and slot it next to the other one, so they are side by side, re-run cpu-z? cant hurt
That's what I just did, memory is now working in dual channel, thanks mate, don't know why I never noticed it before. Will check CoD4 and the heaven bench it a bit.
Sorry, only just got back, CoD4 seems to run better, but I am playing in less demanding places so I thinks that's where the FPS boost is from, heaven is still the same :(
disable cool n quiet in the bios, just to make sure its not sticking at the lower cpu speed.
apart from that it must be a driver issue/setting
