Hey all
Ok basically i haven't benched in a while and i noticed quite low frames in programs and games which has been bugging me all day, i've got my MSI GTX460 today and not sure if i'm happy with it, so i've done a bunch of benching and wanted your reviews on wether these scores are acceptable for my card/system and if there's anything holding me back.
I hopped on a couple of games and noticed the same stuttering/frame rates as my HD 512 4870 which baffled me, so here's the benchmark results:
Uploaded with ImageShack.us
The settings i used for 3dmark06 are 1920x1080p Resolution, x8AA (Quality x3), Anistropic filtering. The FPS i'm currently getting in games is really no better than a HD4870 i've noticed and wondered if there was any cause of this.
Note: The card isn't at all overclocked it's completely stock.
I think all the GTX460 in reviews had no problem overclocking to 830MHz on stock voltage. I've seen reviews where with voltage tweak, the GTX460 can hit 900~950MHz. But I'm not really sure if it is worth it for you, as your CPU is probably holding back the GTX460 a bit, and you might not see further improvement clocking the GTX460 further. But I guess it no loss testing it out...just be careful not put the voltage too high and keep at eye on the temp.
