HALLELUJAH, HALLELUJAH, HALLELUJAH, HALLELUUUUUUJAAAAAAAAAAAAH!
Ditto!
I don't think I have ever seen as many inconsistent review results across hardware sites as I have with the current 5800 series vs. the GTX4xx series. No idea why this is the case because someone is clearly telling porkies!
Buying that video card was like buying a ps3!
Would you say the 5870 is more power than a ps3? I know they use two different types f graphics, but in relative terms?
Yo dood
It uses Mini display port connectors. However, it also comes supplied with 1 x Mini DP to HDMI Cable, 2 x Mini DP to Single Link DVI Cable, and 2 x Mini DP to DP Cable.
Hope that helps dewd
So using the included Mini DP to HDMI Cable I can just plug the video card straight in to my monitor?
(Sorry for the dumbass question just making sure!)
Yeah it's also 40 quid dearer though!Comparing a 58** card to a ps3 lol ? The only reasons stuff on the console looks good is a) they optimize it precisely to the console b) its a TV (resolution) and you are relatively far away. The computing power of all consoles is rubbish and cannot compare to anything this and last gen.
Also the 5870 is simply superior to the 470.
- Ordokai
Since you keep talking about Crysis 2 consider this: this one is also being developed for consoles also. So...it either means it will be much easier on the graphics. Or terrible.
Sorry getting confused, I have VGA and DVI on my monitor only.
I hope the card comes with a cable to connect the dvi on my monitor to one of the mini display ports on the card!
See above ^
