XFX Radeon 5870 - Fan runs at 55% idle - very loud!
30 Dec 2009
Hi,
So I've just go my new pc and it sounds like a jet taking off.
I've been reading up and it seems that for some reason the fan on my card is set to spin at 55% even when idle.
Apparently i can flash the BIOS with an update from XFX that reduces the fan to 30% but I need to do this:
"Once you have formatted your USB flash drive to be DOS bootable
Please add ALL files here (in the downlaod) onto the flash drive and then boot from this drive.
Once at the DOS prompt, please type the following
587XZND.bat
and then follow any on screen instructions."
Can anyone tell me how to do this? I have no idea!
thanks
Dan
25 Mar 2010
Northern Ireland
So your asking how to follow simple instructions?
1.Google how to make your drive dos bootable, then do this.
2. Move the new gfx bios files onto the USB
3. reboot computer and select the USB drive asthe boot drive in BIOS
4. enther the given filename on request
anything else will be simple press enter to continues
Permabanned
31 May 2007
Liverpool
So you're asking how to follow simple instructions?
2. Move the new gfx bios files onto the USB drive
Don't be an arse, it's not simple for everyone.
Permabanned
31 May 2007
Liverpool
15 Jun 2003
Darlington
It sounds like the OP didn't install catalyst.
It's to do with the XFX revision 2 cards the fan speed preset is 55% at idle which is loud.I have 2 of these cards in crossfire and at 55% it sounds like a hoover,i have flashed both of my cards with the new bios on XFX's site and they idle at 30% :)
OP
30 Dec 2009
cheers guys - I wasn't insulted by the way!
I suppose I know what the solution is but I need my hand held.
Not being that technical I live in constant fear of breaking things. I'm going to try the bootable usb thing this evening.
Was annoyed when I turned my PC on yesterday (brand new from ****) to have it sounding like a hoover from the get go. I would have thought someone at Scan would have noticed this and sorted it out before sending to me.
I now find myself having to mess around to get the thing working properly.
thanks again for your responses
Dan.
14 Nov 2007
In the Land of Grey and Pink
Was annoyed when I turned my PC on yesterday (brand new from ****) to have it sounding like a hoover from the get go. I would have thought someone at ****would have noticed this and sorted it out before sending to me.
Dan.
Just a heads up, OCUK don't like mention of competitors.
28 May 2007
Dan.
Cant you return the system as it b0rked ? I would be exchanging the system for a working one. If they start messing you around then DSR it.
Edit: Everyone knows four stars is scan, five stars are *****, six stars are ******.
OP
30 Dec 2009
I suppose I could return it yes, but the thought of packing the thing back up again, taking time of work to arrange for pick up then being without a pc again doesn't really fill my with joy.
28 May 2007
It you flash the cards BIOS you void the warranty and it might not even fix the problem.
I would phone them up and see what they say, they might send a parcel firm to collect it, as really they have sent you a faulty system that should have been built and tested IMO.
OP
30 Dec 2009
I would phone them up and see what they say, they might send a parcel firm to collect it. As really they have sent you a faulty system that should have been built and tested IMO.
Yes good point, I'll contact them to make sure I don't void the warranty if i flash the BIOS. If I do it makes the decision to return the system quite an easy one. For that reason I would expect them to say I don't void the warranty.
OP
30 Dec 2009
To be fair, this is XFX's fault and you'd get the same problem regardless of where you bought it. Just use MSI Afterburner so you don't void your warrantly.
Not really, my contract is with ****. They sent me a PC that has a problem which should have been picked up at quality control.
