froyo for desire starts this weekend
OK, so just want to check I'm understanding correctly how I'm going to get this OTA update on my branded desire;
1. Make a goldcard using 'goldcardtool_0.0.5'.
2. Install RUU_Bravo_HTC_Europe_1.15.405.3_Radio_32.30.00.28U _4.05.00.11_release_121865.exe onto the phone.
3. Go into the phone settings and check for OTA updates.
Is that all? Will my phone now behave as if it were purchased unbranded? Will I need to mess with the goldcard everytime a new OTA update appears???
Many thanks for any answers!
Not to mention bugs so far
GPS no worky,
Time display incorrect,
Market missing a lot of apps, reportedly until Google approve this release of Froyo from HTC for the market
720p at 11 FPS :eek:
The list will grow
The Camera not working now after updating for me :(
EDIT:The camera has now just started working :)
How are people finding the battery life on 2.2? Since updating my battery life is dropping like a rock. Lost 20% in 2 hours 'moderate' use :(
I think mines improved a bit my battery has been sitting on 50% for a good hour 1/2 now and ive been messing with chrome to phone and all sorts. But im not sure if this is switch pro not updating though.
I have a O2 branded phone and have tried doing this but I can't get it to work. It goes fine until I try to install the ROM and I get the message looking for bootloader. It checks about 100 times then gives up and tells me to reconnect my phone.
When I did a hard reset I noticed there was an option to go into bootloader so it is there. When the ROM fails I get left with the hard reset screen but no options just the bulid information and some skateboarding Androids.
Can anyone help?
:confused:
after the hard reset and able to get back into the phone?
Cheers for the links!!!
So after following this will I be able to update direct from HTC using the OTA in the future? Only I don't fancy having to flash etc everytime a new version of the software comes out...
Looking at that link I dare not try rooting.. I have never got debugging mode to work on my desire :O
I was gonna have a go too :/
Anyone finding the browser a bit more sluggish than on 2.1. Been browsing for a while now and it just doesnt feel the same.
Another thing I've now noticed when swyping this out is the swype keyboard doesn't format itself properly when the phone is horizontal so the space key is now below the return one.I'm rather sure it wasn't like this before
