- 9 Feb 2004
- The Planet Houston
Nice writeup mate! CSL noise.... I do miss that.
Let me be the first to say... OMG SPEEDING IN A 30!!!
Seriously though and I can safely say this because i've met you... you are a nutcase!![]()
If its a 2011 then yes not far off.
Remember I am comparing to a CSL here.
An E60 5 series is in a different on interior build quality, but when it comes to mechanical quality then yeah the Mustangs are built using solid components.![]()
I have a friend who writes for Evo I think. If you did get that job, you wouldn't have the income to afford either of the cars in this thread!Every blokes dream job I think. I envy the guys at Top Gear and EVO.![]()
Evo's 5-10 all spool within the RPM range you have stated. My 6 is on full boost by 3k so not sure what you mean by 'well compared to EVO's of old LAG is greatly reduced, the turbo is spooling from 2000rpm and really gets a shift on from 2500rpm onwards with peak torque coming as low as 3500rpm'.
In my experience they are all like that...
Gibbo, what about the fit and finish of the exterior panels, surely that isn't up to German quality?
Out of interest mate how does driving a RHD compare? How much is a RHD > LHD conversion? That mustang looks the sex.
Cheers.
I must have driven a lot of bad EVO's then. My experience on cars 8 and older they all had pretty poor pickup and do not come on full boost until 4800rpm-5500rpm. Infact this is even backed up by manufacturers specifications stating peak torque at 4800rpm, wheras the new ones are 3500rpm, thats a lot more usable power in the rev range.
It was 9 onwards they vastly improved, the introduction of Mivec made them a lot more responsive and the 9 MR models had lighter turbo turbines for quicker spool up hitting peak torque at 3200rpm on the 9 MR 360.
The older cars are only any good when mapped, but even then they don't have Mivec unless you add it to one at quite some cost.
So I'm assuming your 6 is modified then?
My 6 has an exhaust and air filter which were both fitted in the last 10 days.
Sorry Gibbo but what you have quoted as figures is incorrect, unless I'm reading it wrong. An Evo 6 hits peak torque at 3000 rpm, 274ft/lb to be exact.
Full boost by 4800-5000k is crazy, it would be a lag monster and hopelessly awful to drive.
Where did you get these 'manufacturers figures' from? There is a scanned brochure on the MLR.
Have you been driving standard engines with GT35's attached?![]()
