What iPhone 4 accessories are you considering?
Oh good, I've been waiting for the Gelaskins for the iPhone 4. I just ordered one :)
they are awesome designs, i got the royal flush one for my desire....desperatly trying to tell my self i dont want one for my netbook =P
Some people seem unhappy with the Zagg Invisible Shield so what's the best film/screen protector? I'll just be using it with a bumper.
I don't like the sound of the orange-peel effect with Zagg, I can even see it on the videos. Just something properly clear and preferably easy to install?
I'm waiting for my Zagg to arrive. Was an impulse purchase after I promised myself to look after this new iPhone better than the previous one.
Will let you know what it's like after I have it installed.
IMO nothing touches Power Support they just dont have a product over here yet and Im not sure when they will...
I ended up buying the new Bodyguardz Dry Apply as a compromise just to try it out...
BTW it has been reported that ZAGGs have got better but still seem to be the inferior in quality over the main suppliers - I think the lifetime guarantee and UK returns (I think) help sell them though...
ps3ud0 :cool:
ps3ud0 :cool:
What's the Bodyguardz like? Any orange-peel effect? Easy to install?
The BG shields are a lot better (no orange peel texture) then the overrated InvisibleShield's, however they are ever so slightly thinner too. I prefer BG stuff tbh, as I have an IS on the rear of my iPhone 4 at present and for some reason I am getting blister like bubbles - never seen that before on a mature application of the stuff.
I am going away on honeymoon in a few weeks time and I will be using my iPhone to take some snaps and record some video.
I am conscious of it not being snatched. Is there any sort of case anyone can recommend that has a secure strap or similar on it?
where are you going on your honeymoon that being mugged is a worry...?
just treat it like any other easily snatched thing on holiday, dont wave it around unless totally needed and dont get it out in silly places.
ive had my prob with invisishield, when i did the back i also stuck on the lense and flash bit so now when ever flash is used it blurrs out most of the picture some times gives a nice ghostly effect but not what i wanted:/ do bg ones also cover the lens?
Mine doesn't cover the lense or flash at all, I'm guessing you didn't quite get the installation right.
well with the back shield you get a little tab for the lens and flash, i couldn't separate it from the back piece and ended up sticking it it as it was
lol, that's not the best idea :p The additional shield material placed over the lens will ruin camera shots!
Waited and waited for the Power Support screen protector as had one on my 3GS before. Gave up and just received my SGP Steinheil Screen Protection Film - ULTRA CRYSTAL from America. Very impressed - easy to fit and faultless on clarity. Would certainly recommend. :D
