My Gigabyte GTX 460 1GB OC arrived this evening just before 7pm, I hadn't expected it to arrive that late, so was delighted.
I am over the moon with the power consumption of the GTX 460 in idle. With dual-screens or single, the card gracefully ramps down all clocks and voltages, finally reaching 50MHz core, 66MHz memory, and 100MHz shader, 0.8750V. It doesn't matter whether a single-screen or dual-screen is in use, it ramps up/down from this hardcore power-save mode without any flickering! Beats the pants off of a competitors solution in this regard. No need to keep clocks/voltages high, and no flickering = win.
Idle is 33C with the fan at minimum 40%. I think the biggest noise in my case is the three antec fans (P182). I think I might have the HDD cage fan on medium (forgot to check when I opened it), and other fans are on low.
Power usage comparison in idle:
8800GT = 167W idle
GTX 460 = 140W idle
So I'm saving 27W in idle. I'm very pleased with that!
8800GT = 167W idle
GTX 460 = 140W idle
