You are not running x64 windows are you? If you are maybe you need to follow this fix to get Java to work in a command window.
http://forum.xda-developers.com/showthread.php?t=713457
"Andy" or Andy; going to send my phone to SEUK soon for repair. However the form says not to send the battery. I think my battery problem is caused by the battery, could it be the handset*? There is another fault which is handset related (unless it is O2) though - when I use the internet, the signal suddenly drops every few minutes (even I am in the same position) and comes back 5-20 seconds later.
*When using the internet on 3G, the battery drops around 1% per minute.
What switch widget is that? Looks like SwitchPro, but its not on my market![]()
It is SwitchPro, I couldn't find it on the Market Place ether.
Would you like to me upload it?
Whoop rooted my x10miniand removed peggle, edge, roller coaster and wisepilot.
Still having some trouble removing apps like google talk and playnow it just says no file in list, is there a specific way to typing the appname in cmd prompt?
I need to do this to mine - have you got an up to date guide you followed?
SwitchPro isn't free so you might want to remove the link!
whats the latest update via SEUS?
mine is still on 020 and seus says my phone is upto date...
my phone is a debranded CPW phone only purchase
so it dosnt have any branding
