Hi everyone I'm building my Krypton Extreme Intel Core i7 930 2.80GHz @ 4.20GHz Overclocked Bundle (upgraded motherboard) and it came to connecting all the power cables and as this being my first build I'm reading through the manual.
It's says connect the 24 pin connector which ive done and then says connect the 8-pin EATX12V power plugs, the PSU doesnt have then unless its the PCIE connectors which I thought not. But the part that is really confusing me now is theres 1 8-pin and directly below theres a 4-pin and it looks like another 4-pin covered up
Does anyone know what PSU I will need to get these connections, I know that the Corsair HX850watt has one and you can get an adapter but can you get the from OCUK.
Thanks in advance (as I'm about to pull my hair out)
