im still not happy with the keyboards, using the htc modded one at the moment.
really like the iphone keyboard, anything similar that auto completes like the iphone on the SGS?
Got a link to this, man?
Enable predictive text?
At work at moment so can't really search for it. Its a big thread though
Download the switchpro app, allows you to have a widget where you can turn on/off wifi/3G/bluetooth/syncing etc.
It's the bottom widget in this pic:
Ok, Rom Manager, installed it, ran it, installed the clockwork bit, selected the option to backup, phone rebooted, saw the recovery screen for a few seconds then the phone rebooted as normal, so ran the backup again, this time it took a few minutes and i could see the progress bar etc... once finished and rebooted, i used astro to look at the root of the internal sd card, there was a new folder containing several files such as Nandroid and system etc... also in the root of the internal sd card there is an update.zip...
Is the update.zip part of the backup...?
If i flash a new rom and select the option to wipe the cache etc... will that not wipe the internal sd card and thus the existing backup folder and .zip??
Sorry for the newb questions, but trying to find any decent info on this app and whats going on is hard.
Before i did the backup, i did have an update.zip in the root from rooting the phone, but also copied it to the external sd card, having checked both, the one in the root is now twice the size of the backed up root zip, hence i thought rom manager may have done something?
Guess i'll wait for an official update, this all seams a bit too complicated for beta's.
Don't you find launcher pro eats the battery life pretty badly?
Woody I find that launcher pro does eat the battery but I charge every night anyway so it doesn't make much of a difference. Best app killer anyone ?
thats the thing, i dont like predictive text (t9) lol
the htc modded one does what i want but the buttons are too small for my fat fingers. - im sure il get used it to eventually!
3 years with an iphone so have got some what used to its keyboard![]()
