- 3 Nov 2004
- UK
Ooh. Can you get one of those for HTC Desire?
Looks like it adds quite a bit of bulk though...
ok N00b question I'm sure but.
Got this phone yesterday, Its my first android phone and I'm loving it, however... How can I move my widgets around? I've set a few up on the home screen but I don't like the position they are in, for instance I want to centralise the clock and have my stocks in rows instead of columns.
Not sure if its the same on this phone as the rest, but keep your figure on the widget in question, and it will then release so you can move it around.
Been looking at the lag fix, and the best method appears to be an updated Kernel... JM2?
If I flash a new kernal, I take it i would then have to restore my backups from titanium to get settings and apps etc back....?
Whats the best official kernal, Stable? is it still JM2? im so confused, should I just wait for Froyo release, or would the firmware require updating for that anyway???
Check out the xda development forum: http://forum.xda-developers.com/forumdisplay.php?f=665
Should provide some answers.
seems abit high , get rid of the task killer they are not needed . see what happens after that .
If that fails try deleting the battery status file if your rooted
turn of 3g networking when you are not useing it, and set the screen brightness to minimum.
That will roughly double your battery life alone.
Whats the best firmware to install when rooting? Also does rooting remove all your installed apps and data and stuff?
Edit: Can someone please also tell me how to turn on gmail push instead of having it syncing all the time? Thanks
Guys does this sound normal for battery usage?
I charge overnight, unplug at around 07.30AM and my battery usually reaches about 50% by 2pm with little or no use on the phone at all. I have used task killer, and only have facebook, twitter, rssfeed reader running and use the music player for 35mins on the train to work. By 2pm it reaches about 55%, is this normal?
