- 22 Mar 2009
Probably Coolit eco c240 will win over H50/H70.
And when they make a one that will beat my True 120Ext by 10C please let me know![]()
I use the H50 and I have tried many configurations but find having 2 fans makes no difference what so ever...
Has anyone else noticed improvement over running 1 fan to 2 ????
So in my personal view its not the shipped with 2 fans that`s doing the job but the increased radiator or the new design?????
Cheers
mrix
When i had an H50 adding a second fan did not help that much. In fact i was surprised at how little difference going from the single stock fan to 2 high performance fans. I didnt do the most accurate of tests or anything but i wouldnt say i did any better than 1c or maybe 2c after load of p95.
The claims from corsair of the H70 beating out the H50 by 10-13c was laughable. All they done is increased radiator thickness. Its still 120 with thin tubing & limited coolant. How this was meant to improve temps by 10-13c is anyones guess as that puts it in similar leage as full watercooling set up more or less (i know as just gone from H50 to full watercooling set up triple rad/fan etc).
The Hardocp figures show an improvement but i think they seemed to have messed up the load temps. I fail to see how the H70 LOW is beaten by the H50. Its thicker rad with two fans, i dont get how it can lose & yet the HIGH beats out the H50 by several degrees. Its like they got the H50 & H70 LOW mixed up. If the results are correct its only about 3C better than the H50 & is louder & takes up more room. If they have mixed up the picture is is 6-7C improvement & therefore pretty good imo, especially as its only selling around £15 more than the H50. But in either case, its hardly the 10-13c claimed.
You know we don't do business that way. Inside the oven under the described circumstances, our results are accurate.I will not buying H70, I am going to get custom-water full stop! It will beat H70 and in price overall, the custom-water is the best way forward.
really cant see the point of the H series, despite the 101 reviews they are not going head 2 head with high air price/performance.
For people that are going to spend 70+ on this would be better off buying a 120.1 rad, a 20 quid block some 7/16 tubing, cheap pump/res few fittings and create your own water cooling kit, which would perform better![]()
Spec me a custom kit for <£80, that has pump, rad, tubing, block, coolant, res, and fittings.
That's a significant improvement. I hope I can get one soon *hint hint*...
