50MB Virgin Media
I get 50mb 24hrs a day.
I get a solid 6.9mb's through Giganews all the time, and have an avaerage ping of 6-10 in all games :)
For the past week and a half my internet has been atrocious, and I'm with VM 10Mb ADSL iirc. This is probably the first time in 4 years its been this bad.
Oh and no I haven't gone over any type of cap, the horrid speeds I've been getting make it physically impossible for me to reach any sort of cap :p
Last Sunday:
Also notice that was done during off-peak hours, not good.
Oh do you? Well i can assure you when i download through giganews, my connection speed is 6.89kbs, give or take a few kbs
Well I don't see how that is possible.
50M/bits / 8 = 6.25MB/sec - overhead = ~6.23MB/sec
10M/bits / 8 = 1.25MB/sec - overhead = ~1.23Mb/sec (Thats what I get from astraweb with 5 connections - IE the utter MAX my connection can have)
Home connection is synced at 8658Kbits which is 1082KB/sec, but I only get 900KB/sec max...
Your software is lying unless VM are being generous and giving you a 55Mbit connection!!!
Why do you only use 5 connections?
I use 20.
Because 5 saturates my connection? Three saturates it but it's not that stable. I don't see the point in doing anymore, and besides, it reduces the chances of corrupt downloads as the Mac client is abit iffy on the shutdown if you do too much at once.
Well actually if you check your modem's config file you're actually being sent 53Mbps. VM do this to ensure that a customer can still get the full 50Mbps after overheads and minor signal loss over coax.
That said, even if you got the full 53 - which is imposisble, due to overheads etc - you'd still only be pulling 6.63MB/sec (or 6.32MiB/sec). Receiving 6.9MB/sec is impossible, unless your modem config file says something higher than 53Mbps, which they don't.
However I noticed MiNxYyY quoted Kbps... a miscalculation maybe?
This is my astraweb connection.
20 connections
which is 6.36Mbps, which is still higher than the numbers your saying i can achieve.
20 connections
which is 6.36Mbps, which is still higher than the numbers your saying i can achieve.[/quote]
Erm, no. 6336.9KB/sec equates to 50.69Mbps, aka 6.34MB/sec. Well within the realms of the figures I posted above. ;) You said you were getting 6.9 MB/sec, a much higher figure. :p
20 connections
snip
What does your TaskManager say?
You might be one lucky person who gets more than the 50Mb!
Whatever you might say 6.25MB/sec is the utter transfer limit of a 50Mbit connection, unless my networking knowledge is completely out of date, but living with a Computer Science dude Im pretty sure im correct :p
He has posted there i can only achieve a maximum of 6.23, but my SS clearly shows me achieving higher than that :/
As I said above mate, he was wrong to say 6.9MB/sec but the figures he now (much more accurately) quotes are easily correct. Again as I said earlier, VM actually provide 53Mbps not 50Mbps (check your modem config file). I also get 6.32MB/sec downstream, which is almost 51Mbps. That, I can believe. 6.9 was just too high however. ;)
