- 22 Mar 2009
STOCK WILL BE HERE TOMORROW!!!!!
Get it clocked and compare temp with H50-1 with 1 fan!
Ok just read a couple of reviews on the H70 and it does seem to be a definate improvement over the H50 and is a good cpu cooler. Downside i then found a review for the C240 eco and while £20ish more expensive seems to perform much better. Unless corsair get a 240 version out in the next few months i know where i am going to put my money![]()
No one is saying these H50-70 coolers will beat out custom water but what you custom water fans are forgetting not only will the H70 be cheaper then a custom loop it has none of the hassles involved either meaning it is even better value for those who want decent cooling without the hassle and worry. Corsair knows this and thats who these coolers are aimed squarely at not custom water coolers and with other companys like coolit around and others that will enter this market in time they may well get near enough to custom cooling.
Yellowbeard - can you use the H50 backplate and retention ring to attach the H70 ? Speficially I am refering to revision 1 backplate. Ta.
I like the look of the H70, however I have doubts over mounting the cooler inside and blowing in, yes its great for the cooler loop, if you only look at that in isolation, but your transferring the heat back inside the case, so it has to be removed.... again.
surely your not using one of the major advantages of water heat transfer over air. in that heat can be concentrated approx 4x(Cp air around 1kJ/kg K and water 4.179kJ/kg K) such that more heat can be taken away and is easily pumped to outside the system boundary (preferably outside the room too)
apart from being a neat package why are they doing this?
Just need a block, tubing, barbs and clips.
OCZ block £16.99
Tubing £6
Bitpower Barbs x6 £15
Clips £4
Oh yeah fans as well I would probably get the Apache black fans:
x3 £42 (Probably try and get these second hands to drop the price)
No clue, I'm sure they have. The first [H]OCP tests were external AFAIK.So Yellowbeard:
Has anyone ever mounted this type outside
Same as the H50.How long are the tubes on the H70?
Yes but it voids the warranty.could they be expanded?
No clue but I doubt it. GPU cooling is VERY expensive due to the plethora of and ever changing block designs. GPU blocks are large, complex, and expensive to manufacture. IMO, GPU cooling units of this type are a very small niche product and doomed to fail.Lastly Any plans for a 480GTX cooler package Version![]()
