Except that this states that:
'Though Proxima Centauri is the nearest bona fide star, it is possible that one or more as-yet-undetected sub-stellar brown dwarfs may lie closer.'
You've probably read about WISE (Wide Infra-red Survey Explorer). I found this excerpt very interesting (particularly given all the Planet X nonsense floating about at the moment):
'Kirkpatrick says that it's possible that WISE could find an icy, Neptune-sized or bigger object in the far reaches of our solar system -- thousands of times farther from the sun than Earth. There is some speculation amongst scientists that such a cool body, if it exists, could be a brown dwarf companion to our sun. This hypothetical object has been nicknamed "Nemesis."
"We are now calling the hypothetical brown dwarf Tyche instead, after the benevolent counterpart to Nemesis," said Kirkpatrick. "Although there is only limited evidence to suggest a large body in a wide, stable orbit around the sun, WISE should be able to find it, or rule it out altogether."'
So it's possible that a Brown Dwarf orbits our Sun, as a member of our Solar System. Cool![]()
Nemesis
This is interesting too - Sedna
