Anybody else got theirs yet? If so, are all your fittings exactly the same? Although all the ones I got all came Feser bags there is a mix of two different designs. The main difference is the internal bore on one of the designs is noticeably smaller than the second, also the barb is different and they have a slightly wider base. Once everything is tubed up you won't be able to see the difference so at 24p a shot I'm not really complaining, just wondered if this was the case across the board.
Havn't tried them on my tube yet so i hope they aren't a mix of 3/8"ID-1/2"OD and 10/8mm fittings. May be more of a problem if that is the case I suppose. I have 5 of the left hand and 15 of the right hand in this batch for interest.
