Does the Vertex 2E come with a 3.5 inch case mount adaptor?
5 Aug 2006
Derbyshire
As title.
Brother wants the Vertex 2E 60gb but when I bought my Vertex (1st gen) I had to buy a cheap caddy off OCUK to allow the drive to be mounted in my case as I only have 3.5" bays.
Just wondering if the newer gen of drive comes with one as if not I will have to buy one.
if it doesn't I'm pretty sure the length of a 2.5" drive = the width of a 3.5" drive
and where do you suggest he:
screws in the screws
and
plugs in the cables?
think man!
Your best bet is to get stickyback velcro pads and mount it onto the inside wall or ceiling of your case. done. and cheaper than the bracket.
