I was shown and learned how to drive without a clutch at a young age, the theory behind it was I could always get home if the clutch fails, it now forms part of my daily drive, just slip it in the next gear smoothly no need for the clutch, does anyone else do this, can you drive without?
For those who don't know you can start a car in 1st or 2nd on the flat with no throttle, then build up speed, when it's time to change gear come off the revs with slight pressure on the gear and it will pop out, and as the revs are dropping it should pop into the next gear down, the idea is to match the engine revs with gearbox and it will pop in with no grinding.
Down is a little different you have to again back off pop out then raise the revs, I rev high then let them drop down and the box will pop in when matched.
I think it promotes forward planning similar to driving with no brakes, a few mates and the wife have had me drive their car home when the clutch has gone.
Yes auto drivers well done
