I have ACS front and rear splitters, backbox and spoiler that would make your car look awesome![]()
Stop it! My £900 snotter is not worth it.....
(E-mail in trust)
(E-mail in trust)![]()
What engine is it? Is it the M50B25 or the M50B25TU? If its the TU, I'd hazard a guess that it's the VANOS ticking until its warmed up/built some oil pressure.
If its the latter I believe it'll have a big lump on the front of the cam cover.
What is oil consumption like?
Edit: Video does make it sound a bit nasty. It it more tappy or knocky in person?
It "could" be chain slap but I doubt it, as the noise seems to be coming from the bottom/back end, I couldn't really tell on the video as you didn't alter the revs much, but does the noise get quicker until around 2,000 RPM, and then go away?
Is it firing on all 6 cylinders? I'd be tempted to pull the plugs and see what state they are all in.
