Caporegime
- 13 May 2003
- Warwickshire
TechRadar Review
hittman...
As with most comparison reviews, there are pros and cons to each.
From reading that review, they made very clear that each has its advantages and that the final choice is highly subjective: 'It almost comes down to preference'. On the other hand, it's a comparative review; they can't just conclude with 'it depends'.
The HTC Desire is only better if you value the OS / interface / flash / community support more highly than a fantastic screen, as it has the worst screen of all three.
On the other hand, it has a flash, which the Samsung does not.
On the other hand, its 720p video recording is (currently) inadequate.
On the other hand, its build quality appears excellent and the fit and finish make it feel like a high end product.
On the other hand, would you rather have a 4.3" AMOLED screen as opposed to something that felt a bit more solid?
Etc. etc...
There's just no correct answer as each user will have different priorities.
hittman...
Etc. etc...
t-mobile shop wont have any new stock till Tuesday.
thank god to odin. And hey im on newer firmware and a custom rom now so its not all bad! lol Thank god for phones being like little computers you can save now adays was terrified of just having an expensive paper weight.
