The wishbone itself has ball joints in it, the garage need to be specific about the fault as the front wishbone rear bush and wishbone ball joints are seperate parts.
An entire wish bone with ball joints + rear bush kit can be had on ebay for around 200, thats left and right hand side.
I see, just looked at some pictures, its clearer now.
Was that kit 200 with OEM bushes?
I'll ask them to clarify in the morning before I take the car down. If the ball joints have not gone, is it worth replacing them 'just in case', are they likely to cause issues? or should I just stick with the bushes, probably Powerflex as they seem to be the way to go if the OEM ones are rubbish.
