- 29 Nov 2007
vsync set?
258.96 WHQL are on Nvidia's site, I'd recommend you get from there.Going to grab a Gigabyte GTX 460 tomorrow. I've just downloaded the card drivers from the Gigabyte website and they're 258.56. Is it best to always download the drivers from the NVidia website instead?
Got my Gigabyte GTX460 1Gb OC this morning. To be honest, I was very disappointed with it’s performance. I’ve upgraded from a 8800GTS 640Mb OC2. I’ve only run the “X3 - Terran Conflict” benchmark so far and I wasn’t impressed. I’ve gone from an average frame rate of 57.5fps to 62.5fps.
The only good point about the GTX460 is that it’s almost silent. Much quieter than my old 8800GTS and a lot shorter.
msi afternurner is about as simple as it comes u have 3 sliders and like just slide them and click apply...?
Strange it does that...
Mine's at 850/1700/4200 @ 1.087V from the second it hits windows and it's never had a problem.
What brand do you have?
Because that is some mean result right there!
I think Ravenger was hoping to upgrade to a modular one though...
Hey, I currently have a 8800GT and I'm thinking about buying the Gigabyte 460 (for the upgrade and sound reduction on load). I have a SLI compliant mobo, is that how you have the two cards set-up? I have no experience with it, or why you would have this set-up but it would be great if you could explain to the poor uninformed!Mine doesn't run that cool! About 33C now, but I do have an 8800GT installed which pushes the idle temp up a tad.
The second card would most likely be for deadicated Nvida physics, not sli mate![]()
How the hell did you get 28k? What settings is that at?
