Ok here is what I'm thinking of doing, currently i have a new pc with just a 120gb SSD in it, as i barely installl a lot of stuff on my computers as i usually pile everything on my external HDD (1tb)
However recently i've been thinking if my external HDD fails, i've lost near 850gb of pictures/movies which I'd really like to keep, and for such a size i can't really install it on DVDs etc so i thought of raid and i have loads of questions which i'd love to be answered.
1. If i got another identical external HDD can you setup RAID 1 to mirror everything to each drive? So if one dies I'm still fine?
2. If i added 2, 1tb HDD into my computer, how would i go about setting up RAID 1 as i thought you had to do that when installing the OS? and even then don't SSD and HDD use different "settings"
3. In a raid setup, if one drives fails, and i replace it, do i have to setup the raid again, and does the data from the working drive copy itself over when the raid is setup again or do i have to manually copy everything over?
4. How "stable" is raid, as i don't want to waste time if it doesn't work
and lastly 5. Does RAID 1 work with HDDs that have been partioned off, say i split both 1tb drives into 2 500gb drives would it copy the files to the corresponding partion for each drive?
I'd really appreciate any help as I'd love a fail-safe backup solution.
