Help appreciated if you can.
The white tabs dont go down they lift up as you insert it and they lock into the sides of the RAM. In the picture above they definately look odd to me to, saying that I am due an eye test soon so doesnt mean much lol.
Dave.
Yeah, theres 6 slots, 5 of them are "open" due to trying each slot with each of the 3 sticks. but the one closest to the CPU (with the ram in) is locked shut.
Surely them being open or closed when nothing is inside isn't an issue?
Ah, can see it now , told you my eyes were bad lol. Thought the blue socket was a DIMM.
You tried pressing the MEMOK button? or made sure nothings holding that down.
Dave.
Dave.
I aint pressed it as well I don't like touching things I don't know. cooking some pasta at the moment (been working on this PC since 1pm) will repiece it togeher in the opposite slots and try the button also. :)
I let you know if theres any changes in a bit.
Posting from the new PC ^_^
I owe you guys a drink for helping me this evening, sticking the memory in all blue slots (opposite to what the manual says) and hitting the MemoryOk button did it. Failed to instal the driver for the graphics card on first go, but it seems to be running okay currently.
Think I leave it out as it is currently, then put it in the case again tomorrow and see if it's okay under stress.
Much <3
