http://www.overclockers.co.uk/showproduct.php?prodid=WC-005-XS&groupid=962&catid=1530&subcat=1783
These prevent the tubing coming off the barbs. Other than that your good to go.
Get jubilee clips, not plastic clips. Jubilee clips are easier to fasten very tightly. Also get 7/16 tubing and 1/2 barbs - then put the tubing ends in boiling water and slip them over the barbs. That way you may not even need clips at all.
Thank you so much! Only problem now is where do i put the reservoirDo not get 7/16" tubing over 1/2" for your first setup. You're way safer with not screwing anything up and getting 1/2" tubing plus jubilee clips.
This should give you way better temps and be more futureproof. Get 2 Yate Loons for this setup and jubilee clips for securing tubing. Also distilled water and silver coil as a coolant.
Thank you so much! Only problem now is where do i put the reservoir![]()
