Catalyst 10.8 is scheduled for 25th or 26th August
HD content on youtube looks like crap without hardware acceleration, ATI should respect the fact a lot of people who buy their mid to high-end parts overclock and their dodgy fix is not acceptable when you consider Nvidia have no problems at all in this particular area.
I don't watch Youtube videos too often and when I do, I tend to turn of Afterburner for that matter. I don't like to do that though. I'm wondering how many people have the same problem as me.
EDIT: instant Driver Recovery for me even at constant full clocks.
EDIT 2: works fine with max clocks in Overdrive. Must be the Unofficial MSI Afterburner causing troubles. I may try flashing the bios then.
Higher idle temps, power consumption in the long run? Why cause this if can be avoided?
Nvidia's fix for multi monitor(where AMD have most issues) is to force full 3d clocks all the time, yes, its a complete "fix" but requires, I assume fiddling with clocks in the exact same way you'd want to for AMD to get decent 2d and 3d clock settings, so the end user situation for the "ultimate" setup is identical fixes for both AMD and Nvidia, yet some people will have you believe Nvidia can do no wrong and AMD fixes are impossible to find.
Of course, fixing the memory clock, has been known, and possible from DAY ONE of the 5xxx series release, in 6 months knowing all of AMD's issues Nvidia surely managed to fix the timing/memory issues that cause flickering in multimonitor situations to give proper idle clocks that don't flicker........ nope, they didn't get it working perfectly either, perfectly would be idle power clocks, fixed memory speed, and low heat/power output, they don't have that, so its certainly not perfect.
ATi cards have 3 basic clock profiles:
Idle - self explanatory; ~157MHz GPU, 300MHz Memory
Bluray/AVIVO - For when playing dvds, H/W accelerated videos and flash; ~400MHz Gpu, 900MHz Memory (hence the mem clock drops to 900MHz on youtube videos)
3D - Games; max clocks
It works as its supposed to, dont see what the complaint is about
This is where people forget the issues, firstly MS in Jan or so(when the grey screen issue appeared) changed power profiles and some situations in which they appear or not, grey screen bug happened when windows stopped sending out the right power state and AMD cards were trying to do something that required higher clocks, but not being told to clock up, clocking up the cards yourself meant you would NEVER see the grey screen, this started happening after a MS update and never happened before.
There are several power states required for various things, the problem is, after MS made a change, newer cards have a different bios to older cards to sort the situation in hardware, drivers now have to play with TWO sets of cards that have two sets of power state settings, and Nvidia only don't have this problem because their cards were so late that they learnt from AMD and the MS changes happened way before their release, it made it easier, and Nvidia as I said didn't "fix" the situation, they simply had a workaround to use much higher clocks and significantly higher power in certain situations, its a work around, a fix would enable low idle clocks in multimonitor situations.
ITs all a bit of a mess, power states, clocking up and down, people forget turning off parts of a core, clocking down, making a chip stable at several clock speeds and voltages requires extra transistors and core logic.
Its also a pain as the UVD type clock settings really screw things up, theres little point offloading workload from cpu to gpu, if it doesn't save power, if you have to power up your 5870/480 to full power to get a small youtube video in play, you're not saving power at all. On systems with decent cpu's windows should give you the option of not offloading the decoding of basic stuff to gpu's AT ALL, Nvidia or AMD, because its a waste of power to be honest. Yet play a 40gb bluray video and you might well want your gpu to be used.
Neither company has powerplay/(Nvidia's name for powerplay?) working right, both have loads of work arounds for many things, will be 2-3 generations before its all working perfectly, seemlessly and only uses the gpu when it actually saves power or when the cpu is incapable of doing the work alone.
As for the drivers, I have zero issues on 10.7 with xfire, bar setting my own clocks, which I prefer to do anyway and always have, Nvidia/AMD, because you can usually use lower voltage/clocks in just about all idle/2d load situations and higher voltage/clocks in 3d situations on every card I've ever bought, seems a waste not to set your own clocks/voltages for every setting.
If you read the entire thread (or at least the first page), you'd realize I don't complain.....
I've read it all. dont get upset - it wasnt aimed at you. the fact remains while ati are dragging their arses keeping us waiting for a proper fix, there *is* a way to make everything work in the mean time. so why keep moaning, its not like nvidia have their clocking nailed down either, is it?
......but rather argue that higher clocks "fix" isn't something we should be happy about
Nobody said they were 'happy' with the situation. Just that taking over a thread with 'urrghh they still havent fixed the clocking' is tedious and doesn't solve anything.
RavenXXX2 said:
@ Allnamestaken, can you play a youtube vid and tell me what the clocks change to in afterburner.
400/whatever the ram is set to in your overclock. 400/1100 for me. What it doesnt do (at least with firefox) is revert to 2d clocks when the page is shut down - i have to close firefox down completely for the 2d clocks to take hold. This is probably down to afterburner id guess.
edit: actually it's 400/900 for low bitrate content (i mean really low, like 240p or poor 360p) or 400/1100 for everything else right up to the 4k resolution stuff. But again it stays stuck at 3d clocks until firefox is shut down completely.
I haven't played a game yet where catalyst hasn't crashed. So they're gonna have to do something impressive to stop me switching back to nvidia for my next build.
i've had no problems with it crashing on any game ive played. installation issue?
What do I care, I don't use multi-monitors, at least Nvidia don't screw single as well as dual monitor users over.
of course you dont. why should you, all you're capable of is sticking up for who ever manufactures your gear (as long as it works for you) and slamming everything else regardless. you're becoming a cheap parody of easyrider tbh.
yeah, im really screwed over. I think i'm gonna go over there in the corner and cry myself to sleep :(
isnt raven allowed an opinion on here?
ATI drivers do let them down.
Im playing Bioshock 2 at the moment, with a 5870 and the 10.7 drivers, and it plays fine, but when ever i go to a gene bank, I get major image corruption, that dissapears once you exit the gene bank.
For a game like that which came out in Febuary, to still have issues which havent been fixed......
Also STILL get texture corruption in BFBC2.....
:mad:
:mad:
Your not going to start a few more threads on the 5870 are you?:p
That was hard work for all of us last time that posted in your threads (joking)
Thanks for the drivers people, what's the difference between the ATI 10.4 and the A and B? I'm guessing they're just revisions?
:mad:
Its not up to ATI to fix Bioshocks issues...
Bioshock works fine for me.
i really really really just want the dual screen mouse corruption glitch fixed for my 5870. dont care about the rest because this one is staring me in the face 24/7 and makes me want to break expensive stuff! (on a side note, anyone know any fixes for this?)
i have had my 4870 for nearly 2 years, every month i updated the drivers, not once have i had a bad experiance with them. dont why people say some are bad and some are not.
yeah i'm prepared for ati to deliver a brown paper bag full of ****e, and then to set it alight on my doorstep.
