- 8 May 2010
- London
adding any form of waterchiller to a loop is all well and good. you need to ensure that the chiller will remove the heat output from the components and not get overstressed
adding a waterchiller to a loop with an existing radiator doesnt work
air actually warms up the coolant that passes through a radiator
this totally negates the point of chilling the water.
Brilliant - thankyou.
I suppose a fancy control circuit would be sensible; If the water temp is above ambient, fire up the radiator fans. If it's below ambient, don't do so for the reasons you've already outlined.
That projector looks an utter beast. Nice work on getting it! I suppose in line with people's fears about overloading the beer fridge, and also worries about condensation, would it be feasible to perhaps get the chiller's compressor to only activate if the loop temperature rises above (say) 40c? Then the compressor would cut in to help dissipate the heat load of gaming as well as the radiator, but if you're just browsing then you'd give the thing a break?
I'm an automation/controls/systems engineer. Been thinking about diverter valves for a while now for the water but that doesn't help with the cool air. It's looking like I am going to need a custom chiller loop and to run the rad under refridgerant not glycol.
Thoughts at this point are:
1) Air conditioned table (where am I going to put a condenser?)
2) Seperate cool loop for the rest of the system.
Bigger project than I had envisidged
