Just bought a galaxy from o2..£355 and will be here tomorrow. I have had my Hero(i shall try and sell it now) for 3 weeks and made the mistake of trying a friends Galaxy![]()
Guessed they upped the price, they used to be £320+£10 credit.
Turn wifi based location off. Although, it should be turning itself off automatically after determining location.
I'll have a look through the settings, though I don't remember seeing that setting anywhere. Another problem with the WiFi is sometimes it gets 'jammed' so I can't turn it on or off(I think it gets stuck when on), so I have to reboot the phone.
Maybe a firmware upgrade will help? Currently I'm rooted, lag fixed, but using the stock firmware that it came with which is JF1 2.1-update1.
Apart from this ridiculous issue, I really love the phone.
Can anybody recommend me a ROM/Firmware to flash to that may improve stability/performance?
I'd love it if Kies actually worked for me and recognised my phone anyways, let alone the update lol
It will only recognise it with the default launcher. If you plug it in with anything but touchwiz, it doesn't work.
Do you, or anybody else for that matter, know if Rooting and the 1 click lag fix affect the kies connection?
I'm using touchwiz, but have applied those two tweaks and can no longer connect to Kies.
I was able to connect when I first got the phone before I upgraded the firmware to JG5 with Odin.
Cheers
Dan
How easy is it to unlock this phone from simlock (Orange?)
Very easy apparently. Just been discovered the code can be taken off the phone itself
