yeah, and you should check the MM to see the price.
Found it, was a bargain
Should have no problems on your board.
A new GPU may be a good buy, the software you use might be able to use it, i.w CUDA cores?Give it a bit more oomph.
Can you tell me who the hell told you to buy the 870 instead of the 930 ? Cuz that was a waste.
Just under a week ago I came on here asking how to speed up my PC for video encoding
You lot forced me into buying:
a new processor i7 870 and then to give it a little overclock. This then ended up with me buying better RAM, Corsair 2000Mhz, then a better cooling system, Corsair H70. If that wasn't enough, you made me upgraded the motherboard to a Gigabyte UD6 so I could get it to 4.0ghz.
Obviously this new motherboard is SATA6 and USB3.0 compatible so I had to upgraded my external to a Verbatim 1tb USB3.0 and my Internal to a Crucial C300 SSD6.
PLEASE STOP AS I'M RUNNING OUT OF MONEY
My mrs is going to hit the roof when she next looks at the bankexpecially when I told her last month I was buying an iPad because I didn't use the PC much
I believe he bought the 870 as he was already on the 1156 socket...
A nice new Screen would go down well me thinks
