BSOD on boot up after install, nice one ATI.
same here, cant even remove the drivers in safe mode, hmmm
the scaling setting still keeps resetting every time booting in to windows, so they haven't fixed this from 10.8 beta..
same issue as me.Well now my second monitor overscan is not working at boot. I have to put the overscan to the maximum in CCC for it to use my whole screen. Now I have to launch CCC, move the overscan bar just one notch and back and it's fixed. ATI just break something in every new driver release don't they!
This has been around for months? Well, maybe one or two unaware forum users will benefit
To those who don't complain about higher idle clocks/temps - you don't overclock. What are you doing in these Forums anyway?
Something is causing the sleep state resume to act badly for me. I'm 95% sure it's the drivers, reinstalled them manually now not installing Catalyst Control Centre. Will see how it goesI don't want my s3 state to take as much time as booting up does...
.every system is different and reacts different , hence why some having issues, others not..It amazes me the amount of people who call themselves “enthusiasts” can make such a hash of installing drivers. I’ll be installing this tonight over the top of the old ones and I’ll be amazed if I get any of the issues some of you are reporting, I might even make a video of it just to show how straight forward it is.
reboot. then it'll happen againRight i got everything working properly with 10.8 drivers now and idle clocks are correct now, no more 400 idle speed on overclock. I had to use profiles though ofc to counter it like many others have said and its worked fine for me.
with overclock enabled in CCC or afterburner?Sorry to rub it in but i rebooted and my settings have held, im still seeing the 157/300 idle speeds. Seems to be working fine for me.
. However, as an enthusiast, I am aware that all hardware setups are different and that these issues can happen to a small minority.What gpu are you using?
I tried that, ended up worse off when trying to reinstall drivers lol.
