Out the box a GTX470 will be a little slower overall, but with overclocking it will be generally faster - sometimes by quite a bit and far more consistant performance. I have no regrets moving from my heavily OC'd GTX260 SLI (faster than 295) to a GTX470 but I wouldn't be in a hurry to do it again. With almost 40% OC on the 470 tho it is quite a bit faster and definitely more consistant performance wise.
Its not a problem at all
I had a Gainward Dual PCB and it was so loud even on idle. used MSI Afterburner to create a new fan profile and even at 33% the fan was still clearly audiable (lowest it would go)
As for replacing the GTX295, if you overclock the GTX470 it beats a GTX295 at stock settings!
Stock speeds the score was about 14/15k.
And that is with less heat and noise than the GTX295.
2 In SLi would obliterate a GTX295!
I'm probably not a good example of the real temps, etc. for this card tho - I've adapted the temp sensors on my case to feed into a fan controller to regulate intake and exhaust fans to get as close to optimal airflow as possible, also the airflow is divided into 3 "channels" HDD/GPU, SYS (northbridge) and CPU - so in theory the heat from one section doesn't affect temps in another area until we hit saturation on how much can be transferred to the external environment.
What type case fans are you using.
Nvidia must have sorted the drivers from the release ones, as i seem to remember the 5850 was faster in vantage than the 470(Unless my memory is going)
krugga are you saying your 470 is at 1000mhz core?!
I remember reading somewhere that there was allot of variation with Fermi chips, ie some were just naturally allot hotter than others due to differences in leakage etc. so airflow in peoples cases wasn't always the most critical factor but the chips themselves.
heres mine for comparison
i had the fan set high at 80% thou
See my two benches here:
GTX295 (Stock)
Managed to get that to 22k overclocked.
GTX470 (overclocked)
I just found out I was running my 5850 in the 8x PCI-E 2.0 slot for the past few months
Good to see I can achieve clocks equivalent to a stock 480 though.
