May have to sell the 295 to fund another 470 me thinks![]()
It's a bit far to claim people are lying because they call it loud. "Loud" is very subjective to the individual. If the sound doesn't bother you, then great, if you can't hear it, then great, but you could have bad hearing.
Sounds don't bother me, I sleep next to a large fan, I can pretty much ignore sounds, but I know they can and do bother other people a lot.
If you do please let us know how you get on.
As I'm thinking 2x GTX 470 SLI as well
Thanks
Im trying! Haha
Its currently for sale on a popular auction website
Unfortunately I do not currently have access to the members market!
Should make it 200 posts, not 250 lol
Can anybody tell me what the V2 asus GTX470 gives you over the V1?
just been on asus site and there are 2 version of the 470 but only difference i can find is one version comes with a trial of starcraft II
ENGTX470/G/2DI/1280MD5- Free StarCraft II Experience Coupon
- ASUS Exclusive Voltage Tweak Technology for up to 50% performance
- Interactive application "Design Garage" & "Supersonic Sled" bundled for real-time GPU test drive!.
and the other version does not come with the starcraft II trial
ENGTX470/2DI/1280MD5- ASUS Exclusive Voltage Tweak Technology for up to 50% performance
- Extreme gaming satisfaction demonstrated by DirectX 11!
Edit: i was using the uk Asus site but i have just been on the #Global' asus site and found the V2
ENGTX470/2DI/1280MD5/V2- ASUS Exclusive Voltage Tweak Technology for up to 50% performance
Which means i am still none the wiser as it does not mention any improvements over V1 and niether does google up to now
Im at 1087mV and have a clock of 825/1650.
Temps are at 83C and gpu usage has been steady at 85-96% for the last 36 hrs, need to move the card as it is the top card in an multi gpu rig so temps could probably drop 10C if I move it.
If it stays stable until tomorrow, I will go for 850/1700, but only if I move the card and get the temps to drop a bit
Not bad for an OCUK value range card...
Good chance they are - mine does upto 850 at 1.087 - I run it at 800 tho as 850 @ 1.087 is just enough to make the GPU fan audiable over the normal case noise level.
