Erm guys sorry if this is a stupid question, i am on my 4th glass of wine now after having been playing Mafia for a couple of hours. I just went into Afterburner while i was having a cig break and for some reason i decided to play with the voltage slider (don't ask lol). Now here's the thing, i have read that the max voltage for these cards is 1.087v, but my slider goes all the way up to 1.213v
Is this normal? I don't want to hit apply in case i just insta-nuke the VRM's. I am assuming that if 1.087v was the max, then the slider would stop there, or that would simply be the value at the end of the slider.
1.087v i can run 925/1850/2200 all stable...
Any more than that it re-sets. Gpu temp is hitting 84.c and the fan is going mental......
I think i will call it a day on the clocking and get back to trying to like mafia...
When i push mine to far the driver just re-sets.. Not seen a bsod...?
Got my Gigabyte 460 OC (1Gb version) the other day and have to say it is very quiet! Much quieter than my Sapphire 4870 512Mb.
Card runs brilliantly! Very pleased with it. I was a bit nervous as this is my first Nvidia card since the Geforce 2 days.
Me too been Ati for years, I was a bit worried how the Nvidia card would work with my Amd system. So far i have been pleasently supprised...![]()
ASUS GeForce GTX 460 Direct CU Top 1GB DDR5 Dual DVI HDMI PCI Express - Retail - With StarCraft II: Wings of Liberty Trial Game Voucher
775MHz Core, 1550MHz Shader Clock, 768MB 4000MHz GDDR5 Memory, 336 Processors Cores, SLi Ready, Direct X 11 Support, 3 Year Warranty.
with zero errors? that is very impressive
how much real life difference does ocing actually make with the gtx 460
I am going to buy a new card in the morning I think, this will be my first new PC component in a long time, it will replace my GTX260 which has served well .
However, GPU reports 32 ROPS but my clocks are not at the rated 775 for the Top, is this correct or do they ramp up ingame or something?
... Sorry ATI but Nvidia won me backDoes the standard version have 32rops instead of 24 for Asus?
I picked the card up so can hassle the store tomorrow![]()
