Post your OcUK user benchmarks in here!
Up those settings to max. There is no point in having 2 top end gpu's if your not going to max the settings out especially when your minimum frame rate is 181 fps.
it was just a tongue in cheek reply to this...
I thought the whole purpose of this thread was for members to post their personal benchmarks at whatever settings they feel comfortable with.
ok, dirt 2 @ 1920x1080 i7 920 @ 3.6 with 2x vapor-X 5870's 875/1250 ultra 8xAA ect..
still pwning 480's at menu fps with my 5870's, np4meh
Yeah I'm saying it scales well, it should do ']
one thing i noticed while doing the dirt2 bench with CF on/off, and this goes against the grain slightly.. even though i held a good minimum/average fps with 1 5870 @ max settings it stuttered like mad, CF enabled and it was nice and smooth, could it be somthing to do with running @ 120hz? 1 gpu with 60.7fps minimum should also be smooth to look at i'd have thought
xfire running smoother than single cards, that's a first.:p
well ive run the bench with/without CF like i said, ive no other programs running and with only 1 GPU enabled the scenery stutters very noticeably even though min FPS reports as 60.7, with CF enabled and a minimum of 106.5 FPS its super smooth, so yes in my case CF > single gpu
1920x1200 8xAA everything maxed
(sorry for being too lazy to resize the image)
