Caporegime
- 13 May 2003
- Warwickshire
Persuing this isn't worth the hassle.
Nice illustration by the way.
What if the OP's brother was actually a police vehicle? Guess who's fault it would be!What if the van was actually a 7.5 tonne fully laiden lorry and his brakes failed?
You KNOW this how... the van driver did hit someone performing a safe everyday manoeuvre ...
Because this is what the OP has said? Sure, we can all presume the OP is lying, but I am taking the OP as fact. The reality could be that there was an alien spaceship with lasers and pamphlets extolling the virtues of the martian landscape, but that isn't what the OP said has happened.You KNOW this how![]()
Fine, but that's why I said what I did. If the OP is being truthful then his brother was driving pretty normally. To pull me up on making that statement because he may not have been, is totally pointless.PMKeates you are right that this is what the OP said, but without proof that his statement is accurate, it's all peeing into the wind.
Every single car there is "blocking the road". Is it therefore OK to drive in to them if you want to be where they are? When you pull up 2nd in the queue at the traffic lights, the car in front is blocking the road. To hit them is not OK, because they have just as much right to be there as you would.If your going to pull out and block the road expecting then to stop for you then you may as well just pull out infront of them. If this was your test then you would have failed.
You are perfectly within your right to remain stationary in that situation. The other driver doesn't have the right to drive in to you. If an object is obstructing your path, you do not crash in to it. To do so is negligent and careless.But they aren't, there's room for stats and passing traffic. If there's time for him to observe and stop then there's also time for you to observe and roll back.
Whilst quite possibly true, this is entirely irrelevant to the OP's question which wasYou are perfectly within your right to remain stationary in that situation. The other driver doesn't have the right to drive in to you. If an object is obstructing your path, you do not crash in to it. To do so is negligent and careless.
Is there anything we can do, other than "just do nothing"?
Nope; just learn the relevant lessons about observation, caution and not making assumptions about other drivers![]()
