Hi all,
Got all my new parts this evening and put my computer together and proceeded to installed windows 7.
At the install screen it showed my 2 hard drives correctly, 1SSD and and 1TB samsung.
I chose to install to the SSD, which it did....but it also for some really odd reason has installed a 100MB "System Reserved" partition on my 1TB data drive as well. If that wasnt bad enough, it seems that disk mamagement is showing my System, Active, Primary Partiton as the 100MB partition it automatically created on my data disk.
whuuut? I know that windows performace index sees my 1TB drive as the primary disk as my hard drive is the thing that brings my score down.
Im pretty sure this is wrong, what has it done and why?
Should i start from scratch?
