i have the current setup in my sig and i find that the hd i use is a bit sluggish, when i start up it takes a while to start a program, not sure if there is a problem with the registray or it is the hard drive. i`m thinking of getting a primary hard drive i.e. a ssd or a spinpoint not sure if the performance of the hd is not working as good as it should. i.e. the windows experince shows it at a messle 5.8 compared to the gpu and cpu at almost 8.9
i have figured out the problem, i have a stupid but econimcal hard drive which is rather slow, i .e. wd 2 tb green WD20EARS.
what do you recomend for a performance hd, i`ll be getting a ssd maybe next year, i prefer something like a 2tb but will settle for a 500gb hd
can anyone say what the best one would be under a budget of at least £80-100
