This. Might be worth looking into thermoplastic (thermosoftening plastic) and thermosetting polymers.Srsly it depends on the type of plastic.
Eleventy4.
Water melts at 100 degrees, so maybe 80 or 85 degrees for plastic![]()
Did you pluck that piece of information from you're ****? Depends on the type of plastic.
KaHn
Eleventy4.
listen to these people they know the answer
If you read what jp posted you will find out that not all plastics will melt.
So 250 C should be ok for most all plastics, accept for bags & thinner sheets.
