Nvidia GeForce Forceware 260.52 Win 7/Vista 64-bit
Caporegime
8 Sep 2006
On Ocuk
THESE DRIVERS CONTAIN LOW GPU USAGE FIXES , ESPECIALLY BFBC2!. ALSO A NEW LOOK INTERFACE AND OPTIONS!!!!
Gothic and Gothic 2 works fine with this driver
However
This driver has broken OPENCL , might be the same driver that was sent back to nvidia to be fixed. Other than that , everything else is good!
MIRROR 1
http://www.megaupload.com/?d=WP5P9AHX
MIRROR 2
http://www.mediafire.com/?3p8dbgfk3d481vt
Also, it looks like they threw out G80 and older support for now so I made a modded inf for it. Get it here if you need it.
^ Untested FIX from Guru3D
NEW DYNAMIC TILING OPTION ( RECOMMENDED , SAFE , UNSAFE , OFF )
This setting improves the drivers use of multicore cache sharing and may improve performance if increased.
It has been shown to improve multi-gpu scaling when 2 or more cards are enabled in SLI.
I have it set to UNSAFE for testing :)
I'd remove the images Neil, hotlinking is against the forum rules :)
*edit*
ninja!
I like the option for a clean install. Good move there. This is the main reason I'm moving back to nVidia. Fed up of all the hassle of sweeping away drivers and the like with ATI. Remove this, clean this, install here, reinstall over the top, then throw a coin in the wishing fountain and finally your card won't BSOD your PC! :)
I'll reupload asap , people are leeching these drivers as quick as... lol
154MB :p
p.s Keep retrying the link !
Nice retrying worked, downloading at 400k now, hopefully it doesn't kill my connection halfway through lol :)
edit: down to 200k and dropping now, i jinxed myself!
Installed every ATI driver over the top of the previous for a long, long time and haven't ever had install issues.
Its guys like you using tools to clean up drivers that cause you these problems in the first place. I remember using these same tools years ago and they gave me all sorts of problems sometimes resulting in me having to reinstall windows.
All i ever do with ati drivers is uninstall using the catalyst manager then install the new set and surprise surprise it all works fine.
Any how hope these new nv drivers work out good for you guys.
