Out of interest what amp do you run?My £300 setup involves two 75W RMS Rockford Fosgate Powers up front (discount ***) and a 250W RMS 12" sub.
I wouldn't want an amp that was running at 100% powering my stuff, that's all![]()
Well, no, leaving the head unit amp running with no load on the front outputs is not healthy for the output stage. When using an external power amp you are supposed to disable the HU's internal amp (normally a software setting or switch on the unit).When i got my sound system installed I asked about getting the rears uprated, the first thing they said was "It's pointless, don't bother"
Any audio installer should know that it's better to leave the rears hooked up to the HU. I wouldn't be using those guys ever again i know that much.
The amp is running within it's recommended spec - the installer is not at fault, the amp is. I am going to run my Audison at 2ohm load when I can be assed to finish my install and I know for a fact it won't overheat and crap out on me.the amp isnt faulty, the guy who wired it up is. He (she?) is asking it to do too much, much like overclocking a graphics card (when in rome), you can crank it up but it will eventually get too hot and fall over.
For an easy life I would just do this. I don't have rear speakers in my system and it sounds great - you don't have rear speakers in a home stereo set up so why in a car?Rear speakers: Once you get the car back, if the rear speakers are now connected to the HU then they will work.
I'd be tempted to unhook the rear speakers if that is easy enough to do and see if you prefer it with all the sound coming from in front on you (like a band on a stage). You may prefer the sound, but other people prefer the sound from all around hence rear speakers.
I've done away with my rear speakers and I much prefer the way things sound now.![]()
My Audison amp is only 2 * 75 + 1 * 250 watt and is certainly 'half decent'! I don't know much about Planet Audio but I wouldn't write them off as crap just because of the power rating.
True - chances are the amp is either crap and doesn't live up to its claims(personally I've never heard of Planet Audio before..) or the speakers are presenting a lower impedance than we are expecting...no, i quite agree. it's rating means nothing regarding its quality *or* what it can actually do.
we dont know this without knowing what those front and rear speakers are![]()
called in today and he had a look at the amp and found it was putting out 12 volts instead of 8.5 to the speakers (i think) so the amp was running too high, he tweaked it and i went off to test it on the way home. its still doing the same thing so i went back and its now booked in on tues. they are gonna leave it running in the workshop to recreate whats happening then do what ever and try a new amp to see if the same happens.
And you really think it is 1500 watts?I'm running a Jackson 1500W 5 channel amp.
If your amp is 5 channel, how come you are running the rears off the HU?(ignoring the fact one of your channels doesn't work at the moment as I assume it was when you installed it!)As i've said previously, my sound setup is as follows:
2x Rockford Fosgate Powers up front (75W RMS Each)
1x 12" Magnat Sub (250W RMS)
Standard rear speakers are through the HU.
I can't even turn off the HU amp as far as i'm aware, and i've tried every option on the HU that i can find.
Currently getting rid of the amp as Channel 5 has borked leaving me running my sub on 3+4 at the moment. Probably caused by the PCs i lug round in the boot smashing into the amp when i go round corners a bit too enthusiastically![]()
No, it's 1500W max, not RMS. Won't be anything close to that as it's not a particularly expensive amp.
I think this was the point I was trying to make. Your 1500w amp in reality will probably be no more powerful than my Audison 1x250 and 2*75 watt RMS amp. Audison are just more honest in their advertising.
