anyone heard of the brand powercool - power supply.
26 Jun 2010
west yorkshire.
ive got a powercool 950 watt modular, im just a bit mythical as its £90 when a tx 850 is £109.
all it states is its 950 watts
dual 12v rail
sli capable
80+ cert
and modular.
is mine okay ?
would i be able to sli 480s with it if i wanted to hypothetically ?
1 Jul 2007
Various
I haven't heard of them myself, and as such wouldn't trust it to run a grand's worth of kit. That's just me though, if you find it stable it's ultimately down to you.
RJC
RJC
Don
29 May 2005
Kent
They seem a cheaper brand brand which I would not touch, I would personally choose a main brand like Corsair / BeQuiet ect.
22 Jan 2010
If you've already got it and you're not having any problems then I would leave it. It's 80+ and it wasn't crazy cheap. I don't know if I would trust it with dual 480's though :p
OP
26 Jun 2010
west yorkshire.
yeah i mean its running cool, the 2x 480 was only hypothetical, considering you only see 60 fps on general lcds anyway, i dont think ill want more than my oc'ed 470 for now. most ill probably go to is one 490gtx if one ever surfaces.
was only wondering if anyone had heard if they were good or not, cant seem to find a review for them.
13 Jul 2009
Llanelli
AC INPUT: 230V 6A 60/50Hz Model PC-950AUBA-M
+3.3V +5V +12V1 +12V2 +12V3 -12V +5VSB
24A 28A 20A 20A 20A 0.5A 3.0A
950W
It's not a true 950W power supply. It's one of those add all the wattages up jobbies. Has 60W on the 12v rail, so it's a 720W or thereabouts supply really.
18 May 2011
I am not an expert,
950W
But I have trusted a grands worth of kit onto a PowerCool Modular 850W, if I was you I would get a DR. POWER II to check it out, I am going to do so within the next week, I have failsafe tested it with variable resistors to check whether it'd cutout when something shorted and it did, so as far as safety goes it's great, about reliable and stable electrics I do not know yet.
1 Apr 2009
950W
Allegedly. They always make up the numbers, iffy operating temperatures, ect... Unless you refer to a trusted brand like Corsair or Antec, ect... If you know the OEM manufacturer of the PSU, then you will get a better idea.
7 Dec 2010
Leeds
High Efficiency PSU, with 80+ Certification
nVidia SLi and ATi Crossfire Ready
Dual Rail Design
Multi-core CPU support
Advanced Thermal & Accoustic Design
ATX 12V V2.2 Design Guide Compatible
Low noise cooling fan system
ATX 20+4P, 12V 4+4P, 6+2P SLi, 4P Molex, SATA and Floppy Connectors
EZ Connector System
Various Cable Length
New generation design
Specifications
Dimensions : 150 mm x 182 mm x 85 mm
Input Range : 230V, 6A, 60/50Hz
MTBF : 100k hours
Safety : UL, CUL, TUV, EMI
950W
Cheap and nasty stay clear from it mate.. Get yourself a decent brand one like Antec or Corsair or XFX. OCUK have these Powercool PSUs under this name OcUK Battle range ;) so be warned.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-OP&groupid=701&catid=123&subcat=1709
OcUK Battle range PSU
The Powercool 950 PSU.
Only difference is the label at the top as you see. The battle range even says Powercool in the middle of the fan grill.
N$X
N$X
17 May 2004
West Yorkshire
i have had problems previously using inferior brand power supplies. i would stick to a known brand with decent reviews.
not worth the hassle.
15 Feb 2011
Slough
another vote for selling it on and getting something decent here.
if your only planning on using the one GTX 470 then something like the antec 550W modularwould be plenty, but if you plan on using two 470s in SLI then i would recommend the lepa 900W 80+ gold.
i was really after something ~800W for two GTX 470s in SLI, but when theres a 900W 80+ gild modular PSU made by enermax thats cheaper than any other PSU thats powerful enough (and doesnt make funny noises like the OCZ range) then i wouldnt say no
20 Mar 2007
950W
I see 960W 12V, not 60. 60 isn't even enough for the CPU on its own.....
I found a different model, PC-950AUBA-B
26A 32A 17A 17A 17A 17A 0.5A 2.5A
Has 816W 12V
Hmmm, thread necrology, yum!
